OAR
RTEMS 4.5.0 On-Line Library
User Extensions Manager Creating an Extension Set
21.3.1: Creating an Extension Set
The rtems.extension_create directive creates and installs an extension set by allocating a Extension Set Control Block (ESCB), assigning the extension set a user-specified name, and assigning it an extension set ID. Newly created extension sets are immediately installed and are invoked upon the next system even supporting an extension.
