OAR
RTEMS 4.5.0 On-Line Library
User Extensions Manager Directives
21.4: Directives
  • User Extensions Manager EXTENSION_CREATE - Create a extension set
  • User Extensions Manager EXTENSION_IDENT - Get ID of a extension set
  • User Extensions Manager EXTENSION_DELETE - Delete a extension set
  • This section details the user extension manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
