OAR
RTEMS 4.5.0 On-Line Library
Rate Monotonic Manager RATE_MONOTONIC_CANCEL - Cancel a period
19.4.3: RATE_MONOTONIC_CANCEL - Cancel a period
CALLING SEQUENCE:
procedure Rate_Monotonic_Cancel (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - period canceled successfully
RTEMS.INVALID_ID - invalid rate monotonic period id
RTEMS.NOT_OWNER_OF_RESOURCE - rate monotonic period not created by calling task
DESCRIPTION:
This directive cancels the rate monotonic period id. This period will be reinitiated by the next invocation of rtems.rate_monotonic_period with id.
NOTES:
This directive will not cause the running task to be preempted.
The rate monotonic period specified by id must have been created by the calling task.
