OAR
RTEMS 4.5.0 On-Line Library
Rate Monotonic Manager Simple Periodic Task
19.3.7: Simple Periodic Task
This example consists of a single periodic task which, after initialization, executes every 100 clock ticks.
rtems_task Periodic_task()
  rtems_name        name;
  rtems_id          period;
  rtems_status_code status;
  name = rtems_build_name( 'P', 'E', 'R', 'D' );
  status = rate_monotonic_create( name, &period );
  if ( status != RTEMS_STATUS_SUCCESSFUL ) {
    printf( "rtems_monotonic_create failed with status of %d.\n", rc );
    exit( 1 );
  while ( 1 ) {
    if ( rate_monotonic_period( period, 100 ) == RTEMS_TIMEOUT )
      break;
    /* Perform some periodic actions */
  /* missed period so delete period and SELF */
  status = rate_monotonic_delete( period );
    printf( "rate_monotonic_delete failed with status of %d.\n", status );
    exit( 1 );
  status = rtems_task_delete( SELF );    /* should not return */
  printf( "rtems_task_delete returned with status of %d.\n", status );
  exit( 1 );
The above task creates a rate monotonic period as part of its initialization. The first time the loop is executed, the rtems.rate_monotonic_period directive will initiate the period for 100 ticks and return immediately. Subsequent invocations of the rtems.rate_monotonic_period directive will result in the task blocking for the remainder of the 100 tick period. If, for any reason, the body of the loop takes more than 100 ticks to execute, the rtems.rate_monotonic_period directive will return the RTEMS.TIMEOUT status. If the above task misses its deadline, it will delete the rate monotonic period and itself.
