OAR
RTEMS 4.5.0 On-Line Library
Rate Monotonic Manager Canceling a Period
19.3.4: Canceling a Period
The rtems.rate_monotonic_cancel directive is used to stop the period maintained by the specified rate monotonic period. The period is stopped and the rate monotonic period can be reinitiated using the rtems.rate_monotonic_period directive.
