OAR
RTEMS 4.5.0 On-Line Library
Rate Monotonic Manager Processor Utilization Rule Example
19.2.7: Processor Utilization Rule Example
This example illustrates the application of the Processor Utilization Rule to an application with three critical periodic tasks. The following table details the RMS priority, period, execution time, and processor utilization for each task:
Task RMS Priority Period Execution Time Processor Utilization
1 High 100 15 0.15
2 Medium 200 50 0.25
3 Low 300 100 0.33
The total processor utilization for this task set is 0.73 which is below the upper bound of 3 * (2(1/3) - 1), or 0.779, imposed by the Processor Utilization Rule. Therefore, this task set is guaranteed to be schedulable using RMS.
