OAR
RTEMS 4.5.0 On-Line Library
Rate Monotonic Manager Background
19.2: Background
  • Rate Monotonic Manager Rate Monotonic Manager Required Support
  • Rate Monotonic Manager Rate Monotonic Manager Definitions
  • Rate Monotonic Manager Rate Monotonic Scheduling Algorithm
  • Rate Monotonic Manager Schedulability Analysis
  • The rate monotonic manager provides facilities to manage the execution of periodic tasks. This manager was designed to support application designers who utilize the Rate Monotonic Scheduling Algorithm (RMS) to insure that their periodic tasks will meet their deadlines, even under transient overload conditions. Although designed for hard real-time systems, the services provided by the rate monotonic manager may be used by any application which requires periodic tasks.
