OAR
RTEMS 4.5.0 On-Line Library
Scheduling Concepts Manual Round-Robin
18.2.4: Manual Round-Robin
The final mechanism for altering the RTEMS scheduling algorithm is called manual round-robin. Manual round-robin is invoked by using the rtems.task_wake_after directive with a time interval of RTEMS.YIELD_PROCESSOR. This allows a task to give up the processor and be immediately returned to the ready chain at the end of its priority group. If no other tasks of the same priority are ready to run, then the task does not lose control of the processor.
