OAR
RTEMS 4.5.0 On-Line Library
I/O Manager IO_CLOSE - Close a device
16.4.5: IO_CLOSE - Close a device
CALLING SEQUENCE:
procedure IO_Close (
   Major        : in     RTEMS.Device_Major_Number;
   Minor        : in     RTEMS.Device_Minor_Number;
   Argument     : in     RTEMS.Address;
   Return_Value :    out RTEMS.Unsigned32;
   Result       :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - successfully initialized
RTEMS.INVALID_NUMBER - invalid major device number
DESCRIPTION:
This directive calls the device driver close routine specified in the Device Driver Table for this major number. The close entry point is commonly used by device drivers to relinquish exclusive access to a device.
NOTES:
This directive may or may not cause the calling task to be preempted. This is dependent on the device driver being invoked.
