RTEMS automatically initializes all device drivers
when multitasking is initiated via the
rtems.initialize_executive
directive. RTEMS initializes the device drivers by invoking
each device driver initialization entry point with the following
parameters:
The returned status will be ignored by RTEMS. If the driver cannot successfully initialize the device, then it should invoke the fatal_error_occurred directive.
