OAR
RTEMS 4.5.0 On-Line Library
I/O Manager Device Driver Environment
16.2.4: Device Driver Environment
Application developers, as well as device driver developers, must be aware of the following regarding the RTEMS I/O Manager:
Although the RTEMS I/O manager provides a framework for device drivers, it makes no assumptions regarding the construction or operation of a device driver.
