OAR
RTEMS 4.5.0 On-Line Library
Dual-Ported Memory Manager Deleting a DPMA Port
15.3.4: Deleting a DPMA Port
A port can be removed from the system and returned to RTEMS with the rtems.port_delete directive. When a port is deleted, its control block is returned to the DPCB free list.
