OAR
RTEMS 4.5.0 On-Line Library
Dual-Ported Memory Manager Obtaining Port IDs
15.3.2: Obtaining Port IDs
When a port is created, RTEMS generates a unique port ID and assigns it to the created port until it is deleted. The port ID may be obtained by either of two methods. First, as the result of an invocation of the rtems.port_create directive, the task ID is stored in a user provided location. Second, the port ID may be obtained later using the rtems.port_ident directive. The port ID is used by other dual-ported memory manager directives to access this port.
