OAR
RTEMS 4.5.0 On-Line Library
Region Manager Directives
14.4: Directives
  • Region Manager REGION_CREATE - Create a region
  • Region Manager REGION_IDENT - Get ID of a region
  • Region Manager REGION_DELETE - Delete a region
  • Region Manager REGION_EXTEND - Add memory to a region
  • Region Manager REGION_GET_SEGMENT - Get segment from a region
  • Region Manager REGION_RETURN_SEGMENT - Return segment to a region
  • Region Manager REGION_GET_SEGMENT_SIZE - Obtain size of a segment
  • This section details the region manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
