OAR
RTEMS 4.5.0 On-Line Library
Partition Manager Releasing a Buffer
13.3.4: Releasing a Buffer
Buffers are returned to a partition's free buffer chain with the rtems.partition_return_buffer directive. This directive returns an error status code if the returned buffer was not previously allocated from this partition.
