The partition manager provides facilities to dynamically allocate memory in fixed-size units. The directives provided by the partition manager are:
rtems.partition_create - Create a partition
rtems.partition_ident - Get ID of a partition
rtems.partition_delete - Delete a partition
rtems.partition_get_buffer - Get buffer from a partition
rtems.partition_return_buffer - Return buffer to a partition
