OAR
RTEMS 4.5.0 On-Line Library
Event Manager Building an EVENT_RECEIVE Option Set
11.2.3: Building an EVENT_RECEIVE Option Set
In general, an option is built by a bitwise OR of the desired option components. The set of valid options for the rtems.event_receive directive are listed in the following table:
Option values are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each option appears exactly once in the component list. An option listed as a default is not required to appear in the option list, although it is a good programming practice to specify default options. If all defaults are desired, the option RTEMS.DEFAULT_OPTIONS should be specified on this call.
This example demonstrates the option parameter needed to poll for all events in a particular event condition to arrive. The option parameter passed to the rtems.event_receive directive should be either RTEMS.EVENT_ALL or RTEMS.NO_WAIT or RTEMS.NO_WAIT. The option parameter can be set to RTEMS.NO_WAIT because RTEMS.EVENT_ALL is the default condition for rtems.event_receive.
