OAR
RTEMS 4.5.0 On-Line Library
Message Manager Broadcasting a Message
10.3.5: Broadcasting a Message
The rtems.message_queue_broadcast directive sends the same message to every task waiting on the specified message queue as an atomic operation. The message is copied to each waiting task's message buffer and each task is unblocked. The number of tasks which were unblocked is returned to the caller.
