OAR
RTEMS 4.5.0 On-Line Library
Timer Manager TIMER_RESET - Reset an interval timer
8.4.7: TIMER_RESET - Reset an interval timer
CALLING SEQUENCE:
procedure Timer_Reset (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - timer reset successfully
RTEMS.INVALID_ID - invalid timer id
RTEMS.NOT_DEFINED - attempted to reset a when or newly created timer
DESCRIPTION:
This directive resets the timer associated with id. This timer must have been previously initiated with a rtems.timer_fire_after directive. If active the timer is canceled, after which the timer is reinitiated using the same interval and timer service routine which the original rtems.timer_fire_after directive used.
NOTES:
If the timer has not been used or the last usage of this timer was by a rtems.timer_fire_when directive, then the RTEMS.NOT_DEFINED error is returned.
Restarting a cancelled after timer results in the timer being reinitiated with its previous timer service routine and interval.
This directive will not cause the running task to be preempted.
