OAR
RTEMS 4.5.0 On-Line Library
Timer Manager TIMER_CANCEL - Cancel a timer
8.4.3: TIMER_CANCEL - Cancel a timer
CALLING SEQUENCE:
procedure Timer_Cancel (
   ID     : in     RTEMS.ID;
   Result :    out RTEMS.Status_Codes
DIRECTIVE STATUS CODES:
RTEMS.SUCCESSFUL - timer canceled successfully
RTEMS.INVALID_ID - invalid timer id
DESCRIPTION:
This directive cancels the timer id. This timer will be reinitiated by the next invocation of rtems.timer_reset, rtems.timer_fire_after, or rtems.timer_fire_when with id.
NOTES:
This directive will not cause the running task to be preempted.
