OAR
RTEMS 4.5.0 On-Line Library
Timer Manager Initiating an Interval Timer
8.3.3: Initiating an Interval Timer
The rtems.timer_fire_after directive initiates a timer to fire a user provided timer service routine after the specified number of clock ticks have elapsed. When the interval has elapsed, the timer service routine will be invoked from the rtems.clock_tick directive.
