The rtems.task_mode
directive is used to obtain or change the current
execution mode of the calling task. A task's execution mode is
used to enable preemption, timeslicing, ASR processing, and to
set the task's interrupt level.
The rtems.task_restart
directive resets the mode of a task to its
original value.
