OAR
RTEMS 4.5.0 On-Line Library
Task Manager Obtaining Task IDs
5.3.2: Obtaining Task IDs
When a task is created, RTEMS generates a unique task ID and assigns it to the created task until it is deleted. The task ID may be obtained by either of two methods. First, as the result of an invocation of the rtems.task_create directive, the task ID is stored in a user provided location. Second, the task ID may be obtained later using the rtems.task_ident directive. The task ID is used by other directives to manipulate this task.
