OAR
RTEMS 4.5.0 On-Line Library
Task Manager Building a Task Attribute Set
5.2.9: Building a Task Attribute Set
In general, an attribute set is built by a bitwise OR of the desired components. The set of valid task attribute components is listed below:
Attribute values are specifically designed to be mutually exclusive, therefore bitwise OR and addition operations are equivalent as long as each attribute appears exactly once in the component list. A component listed as a default is not required to appear in the component list, although it is a good programming practice to specify default components. If all defaults are desired, then RTEMS.DEFAULT_ATTRIBUTES should be used.
This example demonstrates the attribute_set parameter needed to create a local task which utilizes the numeric coprocessor. The attribute_set parameter could be RTEMS.FLOATING_POINT or RTEMS.LOCAL or RTEMS.FLOATING_POINT. The attribute_set parameter can be set to RTEMS.FLOATING_POINT because RTEMS.LOCAL is the default for all created tasks. If the task were global and used the numeric coprocessor, then the attribute_set parameter would be RTEMS.GLOBAL or RTEMS.FLOATING_POINT.
