OAR
RTEMS 4.5.0 On-Line Library
Task Manager Accessing Task Arguments
5.2.6: Accessing Task Arguments
All RTEMS tasks are invoked with a single argument which is specified when they are started or restarted. The argument is commonly used to communicate startup information to the task. The simplest manner in which to define a task which accesses it argument is:
procedure User_Task (
  Argument : in    RTEMS.Task_Argument_Ptr
Application tasks requiring more information may view this single argument as an index into an array of parameter blocks.
