OAR
RTEMS 4.5.0 On-Line Library
Initialization Manager Shutting Down RTEMS
4.3.2: Shutting Down RTEMS
The rtems.shutdown_executive directive is invoked by the application to end multitasking and return control to the board support package. The board support package resumes execution at the code immediately following the invocation of the rtems.initialize_executive directive.
