OAR
RTEMS 4.5.0 On-Line Library
Initialization Manager The Idle Task
4.2.3: The Idle Task
The Idle Task is the lowest priority task in a system and executes only when no other task is ready to execute. This task consists of an infinite loop and will be preempted when any other task is made ready to execute.
