RTEMS Logo
RTEMS 4.10.2 On-Line Library
Building the GNU Debugger
PREV UP NEXT Bookshelf Getting Started with GNAT/RTEMS
Chapter 6: Building the GNU Debugger
  • Unarchive the gdb Distribution
  • Apply GNAT Patch to GDB
  • Apply RTEMS Patch to GDB
  • GDB with Sparc Instruction Simulation (SIS)
  • GDB with PowerPC Instruction Simulator
  • GDB for DINK32
  • GDB is not currently RTEMS aware. The following configurations have been successfully used with RTEMS applications:
    Other configurations of gdb have successfully been used by RTEMS users but are not documented here.
