Getting Started with GNAT/RTEMS
While in the tools
directory, unpack the compressed
tar files using the following command sequence:
cd tools tar xzf ../archive/gcc-2.8.1.tar.gz tar xzf ../archive/gnat-3.13p-src.tar.gz tar xzf ../archive/binutils-2.10.tar.gz tar xzf ../archive/newlib-1.8.2.tar.gz tar xzf ../archive/
After the compressed tar files have been unpacked, the following directories will have been created under tools.
There will also be a set of scripts in the current directory which aid in building the tools and RTEMS. They are:
When the bit_ada
script is executed later in this process,
it will automatically create two other subdirectories:
Similarly, the bit_gdb
script will create the
subdirectory build-${CPU}-gdb
and
the bit_rtems
subdirectory build-${CPU}-rtems
The directory tree should look something like the following figure:
/whatever/prefix/you/choose/ archive/ gcc-2.8.1.tar.gz gnat-3.13p-src.tar.gz binutils-2.10.tar.gz newlib-1.8.2.tar.gz rtems-ss-DATE.tgz gcc-2.8.1-rtems-gnat-3.13p-20000429.diff.gz binutils-2.10-rtems-gnat-3.13p-20001107.diff newlib-1.8.2-rtems-20000606.diff.gz gnat-3.13p-rtems-20000829.diff hello_world_ada.tgz bit_ada tools/ binutils-2.10/ gcc-2.8.1/ gnat-3.13p-src/ newlib-1.8.2/ bit_ada bit_gdb bit_rtems common.sh user.cfg
