To create a chain you need to declare a chain control then add nodes to the control. Consider a user structure and chain control:
typedef struct foo { rtems_chain_node node; uint8_t char* data; } foo; rtems_chain_control chain;
Add nodes with the following code:
rtems_chain_initialize_empty (&chain); for (i = 0; i < count; i++) { foo* bar = malloc (sizeof (foo)); if (!bar) return -1; bar->data = malloc (size); rtems_chain_append (&chain, &bar->node); }
The chain is initialized and the nodes allocated and appended to the chain. This is an example of a pool of buffers.
