RTEMS Logo
RTEMS 4.10.2 On-Line Library
Configuring a System Device Driver Table
23.2.4: Device Driver Table
This section defines the configuration parameters related to the automatic generation of a Device Driver Table. As rtems/confdefs.h only is aware of a small set of standard device drivers, the generated Device Driver Table is suitable for simple applications with no custom device drivers.
