RTEMS 4.10.2 On-Line Library
Rate Monotonic Manager Directives
RTEMS Ada User's Guide
19.4: Directives
Rate Monotonic Manager RATE_MONOTONIC_CREATE - Create a rate monotonic period
Rate Monotonic Manager RATE_MONOTONIC_IDENT - Get ID of a period
Rate Monotonic Manager RATE_MONOTONIC_CANCEL - Cancel a period
Rate Monotonic Manager RATE_MONOTONIC_DELETE - Delete a rate monotonic period
Rate Monotonic Manager RATE_MONOTONIC_PERIOD - Conclude current/Start next period
Rate Monotonic Manager RATE_MONOTONIC_GET_STATUS - Obtain status from a period
Rate Monotonic Manager RATE_MONOTONIC_GET_STATISTICS - Obtain statistics from a period
Rate Monotonic Manager RATE_MONOTONIC_RESET_STATISTICS - Reset statistics for a period
Rate Monotonic Manager RATE_MONOTONIC_RESET_ALL_STATISTICS - Reset statistics for all periods
Rate Monotonic Manager RATE_MONOTONIC_REPORT_STATISTICS - Print period statistics report
This section details the rate monotonic manager's
directives. A subsection is dedicated to each of this manager's
directives and describes the calling sequence, related
constants, usage, and status codes.
