RTEMS Logo
RTEMS 4.10.2 On-Line Library
I/O Manager Directives
16.4: Directives
  • I/O Manager IO_REGISTER_DRIVER - Register a device driver
  • I/O Manager IO_UNREGISTER_DRIVER - Unregister a device driver
  • I/O Manager IO_INITIALIZE - Initialize a device driver
  • I/O Manager IO_REGISTER_NAME - Register a device
  • I/O Manager IO_LOOKUP_NAME - Lookup a device
  • I/O Manager IO_OPEN - Open a device
  • I/O Manager IO_CLOSE - Close a device
  • I/O Manager IO_READ - Read from a device
  • I/O Manager IO_WRITE - Write to a device
  • I/O Manager IO_CONTROL - Special device services
  • This section details the I/O manager's directives. A subsection is dedicated to each of this manager's directives and describes the calling sequence, related constants, usage, and status codes.
