Getting Started with GNAT/RTEMS
Create a build directory for the SIS Debugger
cd tools mkdir build-sis
Configure the GNU Debugger for the Sparc Instruction Simulator (SIS):
cd tools/build-sis ../gdb-4.17/configure --target-sparc-erc32-aout \ --program-prefix=sparc-rtems- \ --disable-gdbtk \ --enable-targets=all \ --prefix=<INSTALL_POINT_FOR_SIS>
Where <INSTALL_POINT_FOR_SIS> is a unique location where the gdb with SIS will be created.
From tools/build-sis execute the following command sequence:
make all install
NOTE: The make
utility used should be GNU make.
