Getting Started with GNAT/RTEMS
Instead of downloading release tarballs you may choose to check out the current RTEMS source from CVS. For details on accessing RTEMS CVS repository consult http://www.rtems.org/wiki/index.php/RTEMS_CVS_Repository. The steps required to obtain the source code from CVS are usually like the following:
$ cvs -d :pserver:anoncvs@www.rtems.com:/usr1/CVS login Logging in to :pserver:anoncvs@www.rtems.com:2401/usr1/CVS CVS password: $ cvs -d :pserver:anoncvs@www.rtems.com:/usr1/CVS -z 9 co -P rtems # for the main RTEMS source $ cvs -d :pserver:anoncvs@www.rtems.com:/usr1/CVS -z 9 co -P examples-v2 # for examples
