RTEMS Logo
RTEMS 4.10.1 On-Line Library
Thread Manager pthread_attr_getschedparam - Get Scheduling Parameters
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
17.4.16: pthread_attr_getschedparam - Get Scheduling Parameters
CALLING SEQUENCE:
#include <pthread.h>
int pthread_attr_getschedparam(
  const pthread_attr_t *attr,
  struct sched_param   *param
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
EINVAL
The specified scheduler parameter argument pointer is invalid.
DESCRIPTION:
The pthread_attr_getschedparam routine is used to obtain the scheduler parameters field from the thread attribute object attr. The value of this field is returned in param.
NOTES:
As required by POSIX, RTEMS defines the feature symbol _POSIX_THREAD_PRIORITY_SCHEDULING to indicate that the family of routines to which this routine belongs is supported.
