RTEMS 4.10.1 On-Line Library
Memory Management Manager Directives
RTEMS POSIX API User's Guide
12.4: Directives
Memory Management Manager mlockall - Lock the Address Space of a Process
Memory Management Manager munlockall - Unlock the Address Space of a Process
Memory Management Manager mlock - Lock a Range of the Process Address Space
Memory Management Manager munlock - Unlock a Range of the Process Address Space
Memory Management Manager mmap - Map Process Addresses to a Memory Object
Memory Management Manager munmap - Unmap Previously Mapped Addresses
Memory Management Manager mprotect - Change Memory Protection
Memory Management Manager msync - Memory Object Synchronization
Memory Management Manager shm_open - Open a Shared Memory Object
Memory Management Manager shm_unlink - Remove a Shared Memory Object
This section details the memory management manager's directives.
A subsection is dedicated to each of this manager's directives
and describes the calling sequence, related constants, usage,
and status codes.
