RTEMS Logo
RTEMS 4.10.1 On-Line Library
Mutex Manager pthread_mutexattr_setprioceiling - Set the Priority Ceiling
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
10.4.5: pthread_mutexattr_setprioceiling - Set the Priority Ceiling
CALLING SEQUENCE:
#include <pthread.h>
int pthread_mutexattr_setprioceiling(
  pthread_mutexattr_t *attr,
  int                  prioceiling
STATUS CODES:
EINVAL
The attribute pointer argument is invalid.
EINVAL
The attribute set is not initialized.
EINVAL
The prioceiling argument is invalid.
DESCRIPTION:
The pthread_mutexattr_setprioceiling routine is used to set value of the prioceiling attribute. This attribute specifies the priority that is the ceiling for threads obtaining this mutex. Any task obtaining this mutex may not be of greater priority that the ceiling. If it is of lower priority, then its priority will be elevated to prioceiling.
NOTES:
NONE
