RTEMS Logo
RTEMS 4.10.1 On-Line Library
Device- and Class- Specific Functions Manager cfgetispeed - Reads terminal input baud rate
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
6.4.1: cfgetispeed - Reads terminal input baud rate
CALLING SEQUENCE:
#include <termios.h>
int cfgetispeed(
  const struct termios *p
STATUS CODES:
The cfgetispeed() function returns a code for baud rate.
DESCRIPTION:
The cfsetispeed() function stores a code for the terminal speed stored in a struct termios. The codes are defined in <termios.h> by the macros BO, B50, B75, B110, B134, B150, B200, B300, B600, B1200, B1800, B2400, B4800, B9600, B19200, and B38400.
The cfsetispeed() function does not do anything to the hardware. It merely stores a value for use by tcsetattr().
NOTES:
Baud rates are defined by symbols, such as B110, B1200, B2400. The actual number returned for any given speed may change from system to system.
