RTEMS Logo
RTEMS 4.10.1 On-Line Library
Files and Directories Manager utime - Change access and/or modification times of an inode
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
4.4.29: utime - Change access and/or modification times of an inode
CALLING SEQUENCE:
#include <sys/types.h>
int utime(
  const char     *filename,
  struct utimbuf *buf
STATUS CODES:
EACCES
Permission to write the file is denied
ENOENT
Filename does not exist
DESCRIPTION:
Utime changes the access and modification times of the inode specified by filename to the actime and modtime fields of buf respectively. If buf is NULL, then the access and modification times of the file are set to the current time.
NOTES:
NONE
