RTEMS Logo
RTEMS 4.10.1 On-Line Library
Signal Manager alarm - Schedule Alarm
PREV UP NEXT Bookshelf RTEMS POSIX API User's Guide
2.4.18: alarm - Schedule Alarm
CALLING SEQUENCE:
#include <unistd.h>
unsigned int alarm(
  unsigned int seconds
STATUS CODES:
This call always succeeds.
If there was a previous alarm() request with time remaining, then this routine returns the number of seconds until that outstanding alarm would have fired. If no previous alarm() request was outstanding, then zero is returned.
DESCRIPTION:
The alarm() service causes the SIGALRM signal to be generated after the number of seconds specified by seconds has elapsed.
NOTES:
Alarm requests do not queue. If alarm is called while a previous request is outstanding, the call will result in rescheduling the time at which the SIGALRM signal will be generated.
If the notification signal, SIGALRM, is not caught or ignored, the calling process is terminated.
