RTEMS Logo
RTEMS 4.10.1 On-Line Library
Barrier Manager BARRIER_CREATE - Create a barrier
PREV UP NEXT Bookshelf RTEMS C User's Guide
20.4.1: BARRIER_CREATE - Create a barrier
CALLING SEQUENCE:
rtems_status_code rtems_barrier_create(
  rtems_name           name,
  rtems_attribute      attribute_set,
  uint32_t             maximum_waiters,
  rtems_id            *id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - barrier created successfully
RTEMS_INVALID_NAME - invalid barrier name
RTEMS_INVALID_ADDRESS - id is NULL
RTEMS_TOO_MANY - too many barriers created@
DESCRIPTION:
This directive creates a barrier which resides on the local node. The created barrier has the user-defined name specified in name and the initial count specified in count. For control and maintenance of the barrier, RTEMS allocates and initializes a BCB. The RTEMS-assigned barrier id is returned in id. This barrier id is used with other barrier related directives to access the barrier.
RTEMS_BARRIER_MANUAL_RELEASE - only release
Specifying RTEMS_BARRIER_AUTOMATIC_RELEASE in attribute_set causes tasks calling the rtems_barrier_wait directive to block until there are maximum_waiters - 1 tasks waiting at the barrier. When the maximum_waiters task invokes the rtems_barrier_wait directive, the previous maximum_waiters - 1 tasks are automatically released and the caller returns.
In contrast, when the RTEMS_BARRIER_MANUAL_RELEASE attribute is specified, there is no limit on the number of tasks that will block at the barrier. Only when the rtems_barrier_release directive is invoked, are the tasks waiting at the barrier unblocked.
NOTES:
This directive will not cause the calling task to be preempted.
The following barrier attribute constants are defined by RTEMS:
