RTEMS Logo
RTEMS 4.10.1 On-Line Library
Region Manager REGION_EXTEND - Add memory to a region
PREV UP NEXT Bookshelf RTEMS C User's Guide
14.4.4: REGION_EXTEND - Add memory to a region
CALLING SEQUENCE:
rtems_status_code rtems_region_extend(
  rtems_id  id,
  void     *starting_address,
  intptr_t  length
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - region extended successfully
RTEMS_INVALID_ADDRESS - starting_address is NULL
RTEMS_INVALID_ID - invalid region id
RTEMS_INVALID_ADDRESS - invalid address of area to add
DESCRIPTION:
This directive adds the memory which starts at starting_address for length bytes to the region specified by id.
NOTES:
This directive will not cause the calling task to be preempted.
The calling task does not have to be the task that created the region. Any local task that knows the region id can extend the region.
