RTEMS Logo
RTEMS 4.10.1 On-Line Library
Timer Manager TIMER_DELETE - Delete a timer
PREV UP NEXT Bookshelf RTEMS C User's Guide
8.4.4: TIMER_DELETE - Delete a timer
CALLING SEQUENCE:
rtems_status_code rtems_timer_delete(
  rtems_id id
DIRECTIVE STATUS CODES:
RTEMS_SUCCESSFUL - timer deleted successfully
RTEMS_INVALID_ID - invalid timer id
DESCRIPTION:
This directive deletes the timer specified by id. If the timer is running, it is automatically canceled. The TMCB for the deleted timer is reclaimed by RTEMS.
NOTES:
This directive will not cause the running task to be preempted.
A timer can be deleted by a task other than the task which created the timer.
