RTEMS Logo
RTEMS 4.10.1 On-Line Library
Key Concepts Sixteen Bit Object ID Format
PREV UP NEXT Bookshelf RTEMS C User's Guide
2.2.2.2: Sixteen Bit Object ID Format
The sixteen bit format for an object ID is composed of three parts: API, object class, and index. The data type rtems_id is used to store object IDs.
Sixteen Bit Object Id
16 Bit Object Id
The sixteen-bit format is designed to be as similar as possible to the thrity-two bit format. The differences are limited to the eliminatation of the node field and reduction of the index field from sixteen-bits to 8-bits. Thus the sixteen bit format only supports up to 255 object instances per API/Class combination and single processor systems. As this format is typically utilized by sixteen-bit processors with limited address space, this is more than enough object instances.
