RTEMS Logo
RTEMS 4.10.1 On-Line Library
Networking Driver Write the Driver Receive Task
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
15.9: Write the Driver Receive Task
This task should block until a packet arrives from the device. If the device is an Ethernet interface the function ether_input should be called to forward the packet to the network stack. The arguments to ether_input are a pointer to the interface data structure, a pointer to the ethernet header and a pointer to an mbuf containing the packet itself.
