BSP and Device Driver Development Guide
The RTEMS Timing Test Suite requires a benchmark timer. The RTEMS Timing Test Suite is very helpful for determining the performance of target hardware and comparing its performance to that of other RTEMS targets.
This section describes the routines which are assumed to exist by the RTEMS Timing Test Suite. The names used are EXACTLY what is used in the RTEMS Timing Test Suite so follow the naming convention.
