RTEMS Logo
RTEMS 4.10.1 On-Line Library
Clock Driver IO Control
PREV UP next Bookshelf BSP and Device Driver Development Guide
9.6: IO Control
Prior to RTEMS 4.9, the Shared Memory MPCI Driver required a special IOCTL in the Clock Driver. This is no longer required and the Clock Driver does not have to provide an IOCTL method at all.
