RTEMS Logo
RTEMS 4.10.1 On-Line Library
Clock Driver System shutdown
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
9.4: System shutdown
Many drivers provide the routine Clock_exit that is scheduled to be run during system shutdown via the atexit routine. The Clock_exit routine will disable the clock tick source if it was enabled. This can be used to prevent clock ticks after the system is shutdown.
