RTEMS Logo
RTEMS 4.10.1 On-Line Library
Target Dependent Files CPU Dependent Executive Files
PREV UP NEXT Bookshelf BSP and Device Driver Development Guide
2.5: CPU Dependent Executive Files
The CPU dependent files in the RTEMS executive source code are found in the following directory:
cpukit/score/cpu/CPU
where CPU is replaced with the CPU family name.
Within each CPU dependent directory inside the executive proper is a file named CPU.h which contains information about each of the supported CPU models within that family.
